Components
Arm Automotive Solutions comprises of the following main components:
Component |
Version |
Source |
RSE (Trusted Firmware-M) |
53aa78efef274b9e46e63b429078ae1863609728 (based on main branch post v1.8.1) |
cc4c9e017348d92054f74026ee1beb081403c168 (based on main branch post v2.13.0) |
ff0bd5f9bb2ba2f31fb9cec96df917747af9e92d (based on lts-v2.8.6) |
3.22.0 |
602be607198ea784bc5ab1c0c9d3ac4e2c67f1d9 (based on main branch, post v1.0.0) |
2023.07.02 |
4.18 |
6.6.35 |
3.5.0 |
RSE
The Runtime Security Engine (RSE) is a security subsystem, which additionally adds an isolated environment to provide platform security services.
The RSE serves as the Root of Trust for the system, offering critical platform security services and holding and protecting the most sensitive assets in the system.
In the current software stack, the RSE offers:
Secure boot, further details of which can be found in the TF-M Secure boot documentation.
Crypto Service, which provides an implementation of the PSA Crypto API in a PSA Root of Trust (RoT) secure partition, further details of which can be found in the TF-M Crypto Service documentation.
Internal Trusted Storage (ITS) Service, which is a PSA RoT Service for storing the most security-critical device data in internal storage that is trusted to provide data confidentiality and authenticity. Further details can be found in the TF-M Internal Trusted Storage Service documentation.
Protected Storage (PS) Service, which is an Application RoT service that allows larger data sets to be stored securely in external flash, with the option for encryption, authentication and rollback protection to protect the data-at-rest. It provides an implementation of the PSA Secure Storage API in a PSA RoT secure partition. Further details can be found in the TF-M Internal Trusted Storage Service documentation.
Note
The Runtime Security Subsystem (RSS) has been renamed to the Runtime Security Engine (RSE) since TF-M v2.1.0. The downstream patches are not updated and the source code mentions the RSS.
The RSE internally consists of 3 boot loaders and a runtime. The Boot Flow diagram in the Boot Flow section illustrates the high-level software structure of the RSE.
The Secure Services section provides more details of the RSE Runtime and the relevant components.
Note
The release version of TF-M specified in this documentation can be different from that integrated in Kronos implementation.
Refer to the TF-M documentation plaintext in Trusted Firmware-M repository if any mismatch occurs.
Memory Map
The RSE maps the Primary Compute, System Control Processor (SCP), and Safety Island Clusters 0, 1, and 2 system memory regions via an Address Translation Unit (ATU) device to dedicated address spaces. This mapping allows access to those components memories and enables the transfer of the boot images.
From |
To |
Region |
0x0 0040 0000 0000 |
0x0 FFFF FFFF FFFF |
Primary Compute Address Space |
0x1 0000 0000 0000 |
0x1 0000 FFFF FFFF |
System Control Processor Address Space |
0x2 0001 2000 0000 |
0x2 0001 3FFF FFFF |
Safety Island Cluster 0 Address Space |
0x2 0001 4000 0000 |
0x2 0001 5FFF FFFF |
Safety Island Cluster 1 Address Space |
0x2 0001 6000 0000 |
0x2 0001 7FFF FFFF |
Safety Island Cluster 2 Address Space |
Boot Loaders
Refer to RSE-oriented Boot Flow for more details on the boot process.
Runtime
The RSE Runtime provides Crypto Service, PS Service and ITS Service as described above. See Secure Services for more details.
GIC Multiple Views
The GIC has a new optional feature which is intended to be used in mixed criticality systems. This feature provides multiple programming views which can be used by multiple operating systems.
The Safety Island GIC provides 4 programming views:
View-0: Used by RSE to configure View-1/2/3 for Safety Island Cluster 0/1/2 respectively.
View-1: Used by Operating System on Safety Island Cluster 0.
View-2: Used by Operating System on Safety Island Cluster 1.
View-3: Used by Operating System on Safety Island Cluster 2.
Downstream Changes - RD-Kronos
Patches for the RSE are included at yocto/meta-arm-bsp-extras/recipes-bsp/trusted-firmware-m/files/fvp-rd-kronos/ to:
Implement the RD-Kronos platform port, based on RD-Fremont.
Load and boot the SCP.
Load and boot the Safety Island.
Load and boot the AP.
Configure GIC View-1/2/3 for Safety Island.
Configure the NI-710AE of the Safety Island.
Support the runtime services listed above.
Add Secure Firmware Update support for RSE, SCP, Safety Island and Primary Compute.
Add a shutdown handler to be able to shutdown the FVP.
SCP firmware
The Power Control System Architecture (PCSA) describes how systems can be built to provide microcontrollers to abstract various power or other system management tasks away from Primary Compute (PC).
The System Control Processor (SCP) Firmware provides a software reference implementation for the System Control Processor (SCP) component.
For the RD-Kronos platform, the SCP software is deployed on a Cortex-M7 CPU.
The functionality of the SCP includes:
Initialization of the system to manage Primary Compute boot
- Runtime services:
Power domain management
System power management
Performance domain management (Dynamic Voltage and Frequency Scaling)
Clock management
Sensor management
Reset domain management
Voltage domain management
System Control and Management Interface (SCMI, platform-side)
MHUv3 Communication
There are MHUv3 devices between the Cortex-M core where the RSE runs and the Cortex-M core where SCP-firmware runs. In the transport layer of MHUv3, doorbell signals are exchanged between the RSE and SCP.
For RD-Kronos platform, MHUv3 signals are sent:
From SCP to the RSE to indicate that SCP has booted successfully.
From the RSE to SCP to indicate the Primary Compute is ready to boot.
From the RSE to SCP to notify the SCP that the image of a Safety Island (SI) cluster has been loaded to LLRAM and the cluster is ready to boot.
The following diagram illustrates the MHUv3 communication sequence between the RSE and SCP.
Patches for the SCP are included at yocto/meta-arm-bsp-extras/recipes-bsp/scp-firmware/files/fvp-rd-kronos/ to:
Communicate with RSE via MHUv3 to conduct the boot flow.
Power on the Safety Island.
Power on the Primary Compute.
Add Primary Compute and Safety Island shared SRAM to Interconnect memory region map.
Primary Compute
Device Tree
The RD-Kronos FVP device tree contains the hardware description for the Primary Compute. The CPUs, memory and devices are statically configured in the device tree. It is compiled by the Trusted Firmware-A Yocto recipe, bundled in the Trusted Firmware-A flash image at rest and used to configure U-Boot, Linux and Xen at runtime. It is located at yocto/meta-arm-bsp-extras/recipes-bsp/trusted-firmware-a/files/fvp-rd-kronos/rdkronos.dts.
Trusted Firmware-A
Trusted Firmware-A (TF-A) is the initial bootloader on the Primary Compute.
For RD-Kronos, the initial TF-A boot stage is BL2, which runs from a known
address at EL3, using the BL2_AT_EL3 compilation option. This option has
been extended for RD-Kronos to load the FW_CONFIG for dynamic configuration
(a role typically performed by BL1). BL2 is responsible for loading the
subsequent boot stages and their configuration files from the flash containing
the FIP image, which contains:
Patch files can be found at yocto/meta-arm-bsp-extras/recipes-bsp/trusted-firmware-a/files/fvp-rd-kronos/ to:
Compile the
HW_CONFIGdevice tree and add it to the FIP image.Extend
BL2_AT_EL3to load theFW_CONFIGfor dynamic configuration.Support for the OP-TEE SPMC on the RD-Kronos platform.
Add the following device tree nodes to the RD-Kronos platform.
PL180 MMC
PCIe controller
SMMUv3
HIPC
AP_REFCLK non-secure Generic Timer
Assign the shared buffer for the Management Mode (MM) communication between U-Boot and OP-TEE.
Add Secure Firmware Update support for Primary Compute.
OP-TEE
OP-TEE is a Trusted Execution Environment (TEE) designed as a companion to a Normal world Linux kernel running on Neoverse-V3AE cores using the TrustZone technology. OP-TEE implements TEE Internal Core API v1.1.x which is the API exposed to Trusted Applications and the TEE Client API v1.0, which is the API describing how to communicate with a TEE, further details of which can be found in the OP-TEE API Specification.
Patch files can be found at yocto/meta-arm-bsp-extras/recipes-security/optee/files/fvp-rd-kronos/ to:
Implement the RD-Kronos platform port.
Boot OP-TEE as SPMC running at SEL1.
Trusted Services
The Trusted Services project provides a framework for developing and deploying device root-of-trust services for A-profile devices. Alternative secure processing environments are supported to accommodate the diverse range of isolation technologies available to system integrators.
The Reference Software Stack implements the following Secure Services on top of the Trusted Services framework:
See Secure Services for more information.
Patch files can be found at yocto/meta-arm-bsp-extras/recipes-security/trusted-services/files/fvp-rd-kronos/ to:
Support MHUv3 doorbell communication.
Support RSE communication protocol.
Support crypto and secure storage backends for the RD-Kronos platform.
Support transfer capsule update FF-A protocol.
U-Boot
U-Boot is the Normal world second-stage bootloader (BL33 in TF-A) on the
Primary Compute. It consumes the HW_CONFIG device tree provided by
Trusted Firmware-A and provides UEFI services to UEFI applications like Linux
and Xen. The device tree is used to configure U-Boot at runtime, minimizing the
need for platform-specific configuration.
In the current software stack, the U-Boot implementation of the UEFI subsystem uses the FF-A (Arm Firmware Framework for Arm A-profile) driver to communicate with the UEFI SMM Services in the Secure world to store and read UEFI variables that are stored in the Protected Storage Service provided by the RSE.
The implementation is based on the VExpress64 board family. Patch files can be found at yocto/meta-arm-bsp-extras/recipes-bsp/u-boot/files/fvp-rd-kronos/ to:
Enable VIRTIO_MMIO and RTC_PL031 in the base model.
Set max mmc block count to the limitation of PL180.
Add MMC card to the BOOT_TARGET_DEVICES of FVP to support the scenarios of Linux/FreeBSD Distros installation.
Move sev() and wfe() definitions to common Arm header file.
Modify pending callback to test if transmit FIFO is empty in PL01x driver.
Add support for SMCCCv1.2 x0-x17 registers.
Introduce Arm FF-A support.
Introduce armffa command.
Add MM communication support using FF-A transport.
Add Secure Firmware Update support.
Add runtime checks of Update Capsule flags.
Enable capsule authentication as part of Secure Firmware Update.
Xen
Xen is a type-1 hypervisor, providing services that allow multiple computer operating systems to execute on the same computer hardware concurrently. Responsibilities of the Xen hypervisor include memory management and CPU scheduling of all virtual machines (domains), and for launching the most privileged domain (Dom0) - the only virtual machine which by default has direct access to hardware. From Dom0 the hypervisor can be managed and unprivileged domains (DomU) can be launched. Xen is only included in the Virtualization Reference Software Stack Architecture.
Boot Flow
On starting up, the GRUB2 configuration uses the “chainloader” command to
instruct the UEFI services provider (U-boot) to load and run Xen as an EFI
application. Further, Xen reads its configuration (xen.cfg) from the boot
partition of the virtio disk containing the boot arguments for Xen and Dom0
to start the whole system.
MPAM
The Arm Memory Partitioning and Monitoring (MPAM) extension is enabled in Xen. MPAM is an optional extension to Arm® 8.4-A and later versions. It defines a method that software can utilize to apportion and monitor the performance-giving resources (usually cache and memory bandwidth) of the memory system. Domains can be assigned with dedicated system level cache (SLC) slices so that cache contention with multiple domains can be mitigated.
The stack offers several methods for users to configure MPAM for domains:
For Dom0, an optional Xen command line parameter
dom0_mpamcan be used to configure the cache portion bit mask (CPBM) for Dom0. The format of thedom0_mpamparameter is:dom0_mpam=slc:<CPBM in hexadecimal>To use the
dom0_mpamparameter, users can add this parameter to theoptionsof the[xen]section in xen.cfg config file. An example to assign the first 4 portions of SLC to Dom0 at Xen boot time is shown below:[xen] options=(...) dom0_mpam=slc:0xfUsers can also apply MPAM configuration for guests at guest creation time by guest VM configuration file using an optional configuration
mpam. An example is shown below:mpam = ['slc=0xf']There is a set of sub-commands in “xl” to allow users to use MPAM at runtime. Users can use the
xl psr-hwinfocommand to query the system information of MPAM, and usexl psr-cat-setorxl psr-cat-showto configure or read the CPBM for Dom0 and DomU at runtime.The format of
xl psr-cat-setis (-l 0refers to SLC):xl psr-cat-set -l 0 <Domain ID> <CPBM in hexadecimal>The format of
xl psr-cat-showis (-l 0refers to SLC):xl psr-cat-show -l 0More detailed information of the sub-commands, refer to the
--helpof each sub-command respectively.
Limitations of MPAM support in Xen include:
Currently, MPAM support in Xen is available for the system level cache (SLC) partitioning only.
DomU MPAM settings can only be manipulated by xl after the DomU has been created and started.
The FVP only provides the programmer’s view of MPAM. There is no functional behaviour change implemented.
GICv4.1
The GICv4.1 - Direct injection of virtual interrupts (GICv4.1) is enabled in Xen. GICv4.1 is an extension to GICv3 with extra direct Virtual Locality-specific Peripheral Interrupt (vLPI) and Virtual Software-generated Interrupt (vSGI) injection enabled. This feature allows users to describe to the Interrupt Translation Service (ITS) how physical events map to virtual interrupts in advance. If the Virtual Processing Element (vPE) targeted by a virtual interrupt is running, the virtual interrupt can be forwarded without the need to first enter the Xen hypervisor. This can reduce the overhead associated with virtualized interrupts, by reducing the number of times the hypervisor is entered.
With Xen Kconfig CONFIG_GICV4=y, the platform will be automatically
equipped with the capability of all GICv4.1 features.
The stack offers the PCI AHCI SATA Disk for users to utilize GICv4.1 vLPI direct injection for DomU1:
Attach PCI AHCI SATA disk
ahci[0000:00:1f.0]to DomU1 with static PCI passthrough method, by adding the following to the Dom0 Linux kernel command line:xen-pciback.hide=(0000:00:1f.0)In addition, the configuration for DomU1 shall also include a new line of
pci = ['0000:00:1f.0']for enabling the PCI AHCI SATA disk.
For GICv4.1 vLPI/vSGI validation, refer to GICv4.1 vLPI/vSGI Direct Injection Demo.
SVE2
The Scalable Vector Extension version two (SVE2) is enabled in Xen. This feature is used as an extension to AArch64, to allow for flexible vector length implementations.
SVE vector length can be specified as an optional parameter along with enabling SVE2. The allowed values are from 128 to maximum 2048 limited by the hardware supported maximum SVE vector length. Dom0 and guest SVE settings follow the Arm Kronos Reference Design’s maximum vector length of 128. These settings are set in yocto/meta-arm-auto-solutions/recipes-core/domu-package/domu-envs.inc and b/yocto/meta-arm-auto-solutions/recipes-extended/xen-cfg/xen-cfg.bb.
For more information on SVE2, refer to SVE2 guide. Xen command line options for SVE for Dom0 can be found under xen-command-line options and SVE configuration for guests can be found under xl configuration.
For SVE2 validation, refer to Integration Tests Validating SVE2.
Downstream Changes
Patches for the Xen MPAM extension support, PCI Device Passthrough, and GICv4.1 Enablement at yocto/meta-arm-auto-solutions/recipes-extended/xen/files/ to:
Discover MPAM CPU feature.
Initialize MPAM at Xen boot time.
Support MPAM in Xen tools to apply the domain MPAM configuration in userspace at runtime.
Support PCI Device Passthrough.
Discover GICv4.1 feature.
Initialize GICv4.1 at Xen boot time.
Support GICv4.1 features of vLPI and vSGI Direct Injection.
Support EFI capsule update from runtime and on disk.
Linux Kernel
In the Baremetal Architecture, the Linux kernel is a real-time kernel that uses the PREEMPT_RT patch. In the Virtualization Architecture, Dom0, DomU1 and DomU2 run a standard kernel.
Note
Here, the “standard kernel” is a terminology compared to a real-time kernel, a term borrowed from Kernel Types that are defined in the Yocto Project.
Remoteproc
In Linux, a remoteproc driver for the Safety Island is added to the Linux kernel. It is used to support RPMsg communication between the Arm®v9-A cores (from Primary Compute) and the Safety Island. More details on the communication can be found in the HIPC section.
Virtual Network over RPMsg
In order to allow applications to access the remote processor using network
sockets, a virtual network device over RPMsg is introduced. The rpmsg_net
kernel module is added for creating a virtual network device and converting
RPMsg data to network data.
SVE2
The Scalable Vector Extension version two (SVE2) is enabled in Linux. This feature is used as an extension to AArch64, to allow for flexible vector length implementations.
Downstream Changes
The arm_si_rproc and rpmsg_net drivers can be found at
components/primary_compute/linux_drivers.
Additional patches are located at yocto/meta-arm-auto-solutions/recipes-kernel/linux/files related to:
Making the virtio RPMsg buffer size configurable.
Disabling remoteproc virtio RPMsg to use DMA API in Xen guest.
Adding MHUv3 driver.
Safety Island
Zephyr
Zephyr is an open source real-time operating system based on a small footprint kernel designed for use on resource-constrained and embedded systems.
The Reference Software Stack uses Zephyr 3.5.0 as a baseline and
introduces a new board fvp_rd_kronos_safety_island for the Kronos FVP.
It reuses the fvp_aemv8r SoC support and adds a pair of patches for MPU
device region configuration. SMP support is enabled on Safety Island clusters 1
and 2 to allow for Symmetric Multiprocessing.
The Zephyr image for this board is running on the Safety Island clusters. In order to enable communication with Armv9-A cores (from Primary Compute), a set of drivers are added into Zephyr by means of an out-of-tree module. More details on the communication can be found in the HIPC section.
MHUv3
The Arm Message Handling Unit Version 3 (MHUv3) is a mailbox controller for inter-processor communication. In the Kronos FVP, there are MHUv3 devices on-chip for signaling between Armv9-A and Safety Island clusters, using the doorbell protocol. A driver is added into the Zephyr mailbox framework to support this device.
A veth_rpmsg driver is added for socket-based network communication between
Armv9-A and Safety Island clusters. It implements an RPMsg backend by the
OpenAMP library and an adaptation layer for converting RPMsg data to network
data.
Virtual Network over IPC RPMsg Static Vrings
A ipc_rpmsg_veth driver is added for socket-based network communication
between Safety Island clusters. It implements virtual network device based
on IPC RPMsg Static Vrings.
Zperf sample
The zperf sample can be used to stress test inter-processor communication over a virtual network on the FVP. The board overlay dts and configuration file are added to this sample. This sample needs to be used together with iperf on the Armv9-A side for network performance testing.
Downstream Changes
The board support for fvp_rd_kronos_safety_island is located at
components/safety_island/zephyr/src/boards/arm64/fvp_rd_kronos_safety_island.
The out-of-tree driver for virtual network over RPMsg is located at components/safety_island/zephyr/src/drivers/ethernet.
The out-of-tree driver for MHUv3 device is located at components/safety_island/zephyr/src/drivers/mbox.
Additional patches are located at yocto/meta-arm-safety-island/recipes-kernel/zephyr-kernel/files/zephyr related to:
Configuring the MPU region.
Configuring and fixing VLAN.
Working around the shell interfering with network performance.
Adding zperf download bind capability.
Adding SMSC91x driver promiscuous mode.
Fixing connected datagram socket packet filtering.
Fixing race conditions in poll and condvar.
Fixing gPTP message generation correctness.
Fixing gPTP packet priority.
Conforming to the gPTP VLAN rules.
Adding compiler tuning for Cortex-R82.
Adding TCP and UDP receivers stack size Kconfig options.
Adding a ticket spinlock implementation.
