Reproduce
This section of the User Guide describes how to download, configure, build and execute the solutions in this repository.
This repository uses the kas menu tool to configure and customize the different Use-Cases via a set of configuration options provided in the configuration menu.
Note
All command examples on this page from the HTML document format can be copied by clicking the copy button. In the PDF document format, be aware that special characters are added when lines get wrapped.
Build Host Environment Setup
System Requirements
  • x86_64 or aarch64 host to build the stack and execute the FVP
  • Ubuntu Desktop or Server 20.04 Linux distribution
  • At least 500GiB of free disk for the download and builds
  • At least 32GiB of RAM memory
  • At least 12GiB of swap memory
Install Dependencies
  • Follow the Yocto Project documentation on how to install the essential packages required for the build host. The packages needed to build the Yocto Project documentation manuals are not required.
  • Install the kas tool and its optional dependency (to use the “menu” plugin):
    sudo -H pip3 install --upgrade kas==4.3.2 && sudo apt install python3-newt
    For more details on kas installation, see kas Dependencies & installation.
  • Install tmux and telnet (required for the runfvp tool):
    sudo apt install tmux telnet
Download
Note
Performing the builds and FVP execution in a tmux session is mandatory for Arm Automotive Solutions because the runfvp tool that invokes the FVP expects the presence of a tmux session to attach its spawned tmux windows for console access to the processing elements.
Refer to Tmux Documentation for more information on the usage of tmux. It is recommended to change the default history-limit by adding set-option -g history-limit 3000 to ~/.tmux.conf before starting tmux.
Start a new tmux session, via:
tmux new-session -s arm-auto-solutions
To reconnect to an existing tmux session:
tmux attach -t arm-auto-solutions
Download the Arm Automotive Solutions repository using Git and checkout a release, via:
mkdir -p ~/arm-auto-solutions
cd ~/arm-auto-solutions
git clone https://git.gitlab.arm.com/automotive-and-industrial/arm-auto-solutions/sw-ref-stack.git --branch v1.1.1
Upgrading from a previous version
When upgrading from a previous version of Arm Automotive Solutions, which may use a different version of Yocto, you should run the following command to clean the build directory before rebuilding the Use-Cases:
rm -rf build/cache build/tmp*
Reproducing the Use-Cases
General
Kas Build
Arm Automotive Solutions has a kas configuration menu that can be used to build the Use-Cases. It can also apply customizable parameters to build different Reference Software Stack Architecture types.
Note
Before running the configuration menu, ensure it is done inside a tmux session.
To run the configuration menu:
kas menu sw-ref-stack/Kconfig
Note
To build and run any image for an Arms FVP the user has to accept its EULA, which can be done by selecting the corresponding configuration option in the build setup. The Safety Island Actuation Demo is built as part of the default deployment.
The kas build configuration menu selections performed in each use-case are saved. Ensure to only select the options mentioned in the use-case reproduce steps and deselect any other non-relevant ones.
Arm Auto Solutions Build Configuration Menu
Note
Typically, the build process should complete without any interruptions. However, if it is manually interrupted (e.g., by pressing Ctrl-c) or due to network/resource failures, errors may occur when rerunning the build, such as:
NOTE: Reconnecting to bitbake server...
NOTE: No reply from server in 30s (for command <command> at 10:11:08.527092)
This happens because some processes might still be running in the background. To resolve this, you can manually terminate them using: killall -e Cooker
Check for lock files and ensure there are no leftover lock files from the previous build. You can locate and remove them with: find . -name "bitbake.lock" -exec rm -f {} \;
If the above steps don’t resolve the issue, a system reboot might help clear any lingering problems.
FVP
The runfvp tool that invokes the FVP creates one tmux terminal window per processing element. The default window displayed will be that of the Primary Compute terminal titled as terminal_ns_uart0. User may press Ctrl-b w to see the list of tmux windows and use arrow keys to navigate through the windows and press Enter to select any processing element terminal.
The Reference Software Stack running on the Primary Compute can be logged into as root user without a password in the Linux terminal.
Note
FVPs, and Fast Models in general, are functionally accurate, meaning that they fully execute all instructions correctly, however they are not cycle accurate. The main goal of the Reference Software Stack is to prove functionality only, and should not be used for performance analysis.
Critical Application Monitoring Demo
The demo can be run on the Baremetal Architecture or Virtualization Architecture. See Critical Application Monitoring Demo for further details.
Build
To build a Baremetal Architecture image:
  1. Select Critical Application Monitoring Demo from the Use-Case menu.
  2. Select Baremetal from the Reference Software Stack Architecture menu.
  3. Select Build.
Run the FVP
To start the FVP and connect to the Primary Compute terminal (running Linux):
kas shell -c "../layers/meta-arm/scripts/runfvp -t tmux --verbose"
The user should wait for the system to boot and for the Linux prompt to appear.
The Safety Island (SI) Cluster 1 terminal running cam-service is available via the tmux window titled terminal_uart_si_cluster1. For ease of navigation, it’s recommended to join the SI Cluster 1 terminal window to the Primary Compute terminal window in order to issue commands on it.
Follow the steps below to achieve the same:
  1. Ensure that the tmux window titled terminal_ns_uart0 is selected. If not, press Ctrl-b w from the tmux session, navigate to the tmux window titled terminal_ns_uart0 using the arrow keys, then press the Enter key.
  2. Press Ctrl-b : and then type join-pane -s :terminal_uart_si_cluster1 -h followed by pressing Enter key to join the SI Cluster 1 terminal window to the Primary Compute terminal window.
Refer to the following image of the tmux panes rearrangement. Panes can be navigated using Ctrl-b followed by the arrow keys.
Critical Application Monitoring Demo Reproduce Startup
The Reference Software Stack running on the Primary Compute can be logged into as root user without a password in the Linux terminal. Run the below command to guarantee that all the expected services have been initialized.
systemctl is-system-running --wait
Wait for it to return. The expected terminal output is running.
Run the Demo
Before running cam-app-example, .csd files corresponding to event streams produced by cam-app-example must be created and deployed to the system where cam-service runs (in this case SI Cluster 1). Run cam-app-example in calibration mode and then use cam-tool to generate the .csd files.
  1. Start cam-app-example in calibration mode from the Primary Compute terminal:
    cam-app-example -u 11085ddc-bc10-11ed-9a44-7ef9696e -t 3000 -c 10 -s 4 -C
    The stream event log files (.csel) for each stream are generated. The output should look as below:
    Cam application configuration:
        Service IP address: 127.0.0.1
        Service port: 21604
        UUID base: 11085ddc-bc10-11ed-9a44-7ef9696e
        Stream count: 4
        Processing period (ms): 3000
        Processing count: 10
        Multiple connection support: false
        Calibration mode support: true
        Calibration directory: ./[uuid].csel
        Fault injection support: false
        Event(s) interval time (ms): 0
    Using libcam v1.0
    Starting activity...
        Stream 0 sends event 0
        Stream 1 sends event 0
        Stream 2 sends event 0
        Stream 3 sends event 0
    List the files generated:
    ls -1 *.csel
    The stream event log files can be shown as below:
    11085ddc-bc10-11ed-9a44-7ef9696e0000.csel
    11085ddc-bc10-11ed-9a44-7ef9696e0001.csel
    11085ddc-bc10-11ed-9a44-7ef9696e0002.csel
    11085ddc-bc10-11ed-9a44-7ef9696e0003.csel
  2. Run cam-tool from the Primary Compute terminal to analyze stream event log files and convert them to stream configuration files (.csc.yml).
    cam-tool analyze -m 1000000 -i 11085ddc-bc10-11ed-9a44-7ef9696e0000.csel
    The analysis result is reported from the Primary Compute terminal as below, the timeout value might change:
    CAM event log analyze report:
    Input event log file:                   11085ddc-bc10-11ed-9a44-7ef9696e0000.csel
    Output configuration file:              analyzed.csc.yml
    Stream UUID:                            11085ddc-bc10-11ed-9a44-7ef9696e0000
    Stream name:                            CAM STREAM  0
    Timeout between init and start:         300000
    Timeout between start and event:        450000
    Application running times:              1
    Processing count in each run:           [10]
    Event ID        timeout
    0               4000106
    The stream configuration files contain human-readable settings used for the deployment phase of a critical application. Users can modify this configuration, for example to fine tune timeout values depending on the system capabilities.
    Run cam-tool three more times for each of the other three streams.
    cam-tool analyze -m 1000000 -i 11085ddc-bc10-11ed-9a44-7ef9696e0001.csel
    cam-tool analyze -m 1000000 -i 11085ddc-bc10-11ed-9a44-7ef9696e0002.csel
    cam-tool analyze -m 1000000 -i 11085ddc-bc10-11ed-9a44-7ef9696e0003.csel
    Then, use the cam-tool pack command for each of the streams to generate deployment data.
    cam-tool pack -i 11085ddc-bc10-11ed-9a44-7ef9696e0000.csc.yml
    cam-tool pack -i 11085ddc-bc10-11ed-9a44-7ef9696e0001.csc.yml
    cam-tool pack -i 11085ddc-bc10-11ed-9a44-7ef9696e0002.csc.yml
    cam-tool pack -i 11085ddc-bc10-11ed-9a44-7ef9696e0003.csc.yml
  3. Run the cam-tool deploy command from the Primary Compute terminal to transfer the generated stream deployment data to SI Cluster 1 (where cam-service is running):
    cam-tool deploy -i 11085ddc-bc10-11ed-9a44-7ef9696e0000.csd -a 192.168.1.1
    The output on the SI Cluster 1 terminal should look as below, the connection number might change:
    Connection 4 is created.
    Deploy Message
    Connection 4 is closed.
    After that, the stream data of 11085ddc-bc10-11ed-9a44-7ef9696e0000 is deployed to the cam-service file system.
    Running cam-tool deploy three more times can deploy the data of three other streams to cam-service.
    cam-tool deploy -i 11085ddc-bc10-11ed-9a44-7ef9696e0001.csd -a 192.168.1.1
    cam-tool deploy -i 11085ddc-bc10-11ed-9a44-7ef9696e0002.csd -a 192.168.1.1
    cam-tool deploy -i 11085ddc-bc10-11ed-9a44-7ef9696e0003.csd -a 192.168.1.1
    The output on the SI Cluster 1 terminal after each one of the cam-tool deploy command should look as below, the connection number might change:
    Deploy Message
    List all the files from the SI Cluster 1 terminal:
    fs ls RAM:/
    The stream deployment data can be shown as below:
  4. Start cam-app-example from the Primary Compute terminal to create an application with four streams. Each stream sends an event message 10 times with a period of 3000 milliseconds.
    cam-app-example -u 11085ddc-bc10-11ed-9a44-7ef9696e -t 3000 -c 10 -s 4 -a 192.168.1.1
    The following configure messages are expected from the Primary Compute terminal:
        Service IP address: 192.168.1.1
        Service port: 21604
        Stream count: 4
        Calibration mode support: false
    Using libcam v1.0
    And the log of sent event messages are shown repeatedly:
    As observed from the SI Cluster 1 terminal, cam-service is loading four stream deployment files for monitoring. In the following log, the stream messages are received and processed by it:
    Init Message
    Stream 11085ddc-bc10-11ed-9a44-7ef9696e0001 configuration is loaded.
    Init Message
    Stream 11085ddc-bc10-11ed-9a44-7ef9696e0000 configuration is loaded.
    Init Message
    Stream 11085ddc-bc10-11ed-9a44-7ef9696e0002 configuration is loaded.
    Init Message
    Stream 11085ddc-bc10-11ed-9a44-7ef9696e0003 configuration is loaded.
    Start Message
    Start Message
    Start Message
    Start Message
    Event Message
    Event Message
    Event Message
    Event Message
    Event Message
    # Repeated event messages
  5. cam-app-example has a mode to inject a fault to test the CAM framework. Run cam-app-example again from the Primary Compute terminal with fault injection to event stream 0:
    cam-app-example -u 11085ddc-bc10-11ed-9a44-7ef9696e -t 3000 -c 10 -s 4 -f -S 0 -T 1000 -a 192.168.1.1
        Service port: 21604
        UUID base: 111085ddc-bc10-11ed-9a44-7ef9696e
        Stream count: 4
        Fault injection support: true
        Fault injection time: 1000
        Fault injection stream: 0
    Using libcam v1.0
    The fault happens 1000ms after stream initialization. At that time cam-service should detect a stream temporal error with the following output from the SI Cluster 1 terminal.
    ERROR: Stream temporal error:
    ERROR:     stream_name: CAM STREAM  0
    ERROR:     stream_uuid: 11085ddc-bc10-11ed-9a44-7ef9696e0000
    ERROR:     event_id: 0
    ERROR:     time_received: 0
    ERROR:     time_expected: 1710328901375511
    ERROR: Stream state error:
    ERROR:     timestamp: 1710328927375278
    ERROR:     current_state: Failed state
    ERROR:     requested_state: In-progress state
Note
time_received: 0 should be ignored as the time_received is not set during a fault.
  1. To shut down the FVP and terminate the emulation automatically, issue the following command on the Primary Compute terminal.
    shutdown now
    The below messages indicate the shutdown process is complete.
    [  OK  ] Finished System Power Off.
    [  OK  ] Reached target System Power Off.
    reboot: Power down
Automated Validation
Run this step to ensure the creation of the initial firmware flash images:
kas shell -c "bitbake firmware-fvp-rd-kronos -C deploy"
To run the validation tests:
  1. Select Critical Application Monitoring Demo as Use-Case.
  3. Select Run Automated Validation from the Runtime Validation Setup menu.
  4. Select Build.
The complete test suite takes around 40 minutes to complete. See Integration Tests Validating the Critical Application Monitoring Demo for more details.
The following messages are expected in the output to validate this Use-Case:
RESULTS - test_40_cam.CAMServiceTest.test_cam_service_boot_on_si: PASSED (0.00s)
RESULTS - test_40_cam.CAMTest.test_cam_app_example_to_service_on_si: PASSED (36.89s)
RESULTS - test_40_cam.CAMTest.test_cam_app_example_to_service_on_si_with_multiple_connections: PASSED (36.98s)
RESULTS - test_40_cam.CAMTest.test_cam_ptp_sync: PASSED (0.00s)
RESULTS - test_40_cam.CAMTest.test_cam_tool_deploy_to_si: PASSED (75.69s)
RESULTS - test_40_cam.CAMTest.test_cam_tool_pack: PASSED (74.72s)
RESULTS - test_40_cam.CAMTest.test_data_calibration: PASSED (187.73s)
RESULTS - test_40_cam.CAMTest.test_logical_check_on_si: PASSED (15.63s)
RESULTS - test_40_cam.CAMTest.test_temporal_check_on_si: PASSED (44.32s)
Note
There is a rare known failure where a timeout might occur during test execution.
Refer to Known Issues for possible workarounds.
Build
To build a Virtualization Architecture image:
  2. Select Virtualization from the Reference Software Stack Architecture menu.
  3. Select Build.
Run the FVP
Since both DomU1 and DomU2 will be used to run cam-app-example, it is also recommended to create a tmux pane to connect to DomU2.
  1. Press Ctrl-b and the arrow keys to navigate to the terminal_ns_uart0 pane.
  2. Press Ctrl-b " to split the pane horizontally. The bottom pane will be used to connect to DomU2.
Please refer to the following image of the tmux panes rearrangement. Panes can be navigated using Ctrl-b followed by the arrow keys.
Critical Application Monitoring Demo Reproduce Startup for Virtualization
Note
A message similar to the following might appear in the Primary Compute terminal (XEN) d2v0: vGICR: SGI: unhandled word write 0x000000ffffffff to ICACTIVER0, this is an expected behavior.
Run the Demo
  1. From the Primary Compute terminal, enter the DomU1 console using the xl tool:
    xl console domu1
    DomU1 can be logged into as root user without a password in the Linux terminal. This command will provide a console on the DomU1. To exit, enter Ctrl-] (to access the FVP telnet shell), followed by typing send esc into the telnet shell and pressing Enter. See the xl documentation for further details.
  2. To improve the readability of commands and output on the DomU1 console, run the command below:
    stty rows 76 cols 282
  3. From the host terminal, SSH to the FVP then enter the DomU2 console using the xl tool:
    ssh root@127.0.0.1 -p 2222
    xl console domu2
    DomU2 can be logged into as root user without a password in the Linux terminal. This command will provide a console on the DomU2. To exit, enter Ctrl-] (to access the FVP telnet shell), followed by typing send esc into the telnet shell and pressing Enter. See the xl documentation for further details.
  4. To improve the readability of commands and output on the DomU2 console, run the command below:
  5. From the DomU1 terminal, check that the clock is synchronized using the command timedatectl, one of the line of its output needs to be System clock synchronized: yes to confirm that the clock is synchronized:
    timedatectl
    The output should look as below, the date and time can differ, in case the System clock synchronized: shows the no value, allow at least 1 minute for the system to settle and for the clock to synchronize, afterwards repeat the step 5 until System clock synchronized: yes is shown in the output:
                   Local time: Thu 2024-03-14 12:56:26 UTC
               Universal time: Thu 2024-03-14 12:56:26 UTC
                     RTC time: n/a
                    Time zone: UTC (UTC, +0000)
                  NTP service: n/a
              RTC in local TZ: no
  6. Start cam-app-example in calibration mode from the DomU1 terminal:
        Service port: 21604
        Stream count: 4
    Using libcam v1.0
    ls -1 *.csel
  7. Run cam-tool from the DomU1 terminal to analyze stream event log files and convert them to stream configuration files (.csc.yml).
    The analysis result is reported from the DomU1 terminal as below, the timeout value might change:
    Event ID        timeout
    0               4000072
  8. Run the cam-tool deploy command from the DomU1 terminal to transfer the generated stream deployment data to SI Cluster 1 (where cam-service is running):
    Deploy Message
    Deploy Message
  9. From the DomU2 terminal, check that the clock is synchronized using the command timedatectl, one of the line of its output needs to be System clock synchronized: yes to confirm that the clock is synchronized:
    timedatectl
    The output should look as below, the date and time can differ, in case the System clock synchronized: shows the no value, allow at least 1 minute for the system to settle and for the clock to synchronize, afterwards repeat the step 9 until System clock synchronized: yes is shown in the output:
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
  10. Start cam-app-example in calibration mode from the DomU2 terminal:
    cam-app-example -u 22085ddc-bc10-11ed-9a44-7ef9696e -t 2000 -c 5 -s 2 -C
        Service port: 21604
        UUID base: 22085ddc-bc10-11ed-9a44-7ef9696e
        Stream count: 2
        Processing period (ms): 2000
        Processing count: 5
    Using libcam v1.0
    ls -1 *.csel
    22085ddc-bc10-11ed-9a44-7ef9696e0000.csel
    22085ddc-bc10-11ed-9a44-7ef9696e0001.csel
  11. Run cam-tool from the DomU2 terminal to analyze stream event log files and convert them to stream configuration files (.csc.yml).
    cam-tool analyze -m 1000000 -i 22085ddc-bc10-11ed-9a44-7ef9696e0000.csel
    The analysis result is reported from the DomU2 terminal as below, the timeout value might change:
    Input event log file:                   22085ddc-bc10-11ed-9a44-7ef9696e0000.csel
    Stream UUID:                            22085ddc-bc10-11ed-9a44-7ef9696e0000
    Processing count in each run:           [5]
    Event ID        timeout
    0               3000001
    Run cam-tool for the other stream.
    cam-tool analyze -m 1000000 -i 22085ddc-bc10-11ed-9a44-7ef9696e0001.csel
    cam-tool pack -i 22085ddc-bc10-11ed-9a44-7ef9696e0000.csc.yml
    cam-tool pack -i 22085ddc-bc10-11ed-9a44-7ef9696e0001.csc.yml
  12. Run the cam-tool deploy command from the DomU2 terminal to transfer the generated stream deployment data to SI Cluster 1 (where cam-service is running):
    cam-tool deploy -i 22085ddc-bc10-11ed-9a44-7ef9696e0000.csd -a 192.168.1.1
    Deploy Message
    After that, the stream data of 22085ddc-bc10-11ed-9a44-7ef9696e0000 is deployed to the cam-service file system.
    Running cam-tool deploy one more time deploys the data of the other stream to cam-service.
    cam-tool deploy -i 22085ddc-bc10-11ed-9a44-7ef9696e0001.csd -a 192.168.1.1
    Deploy Message
  13. List all the files from the SI Cluster 1 terminal:
    fs ls RAM:/
  14. Start cam-app-example from the DomU1 terminal to create an application with four streams. Each stream sends an event message 10 times with a period of 3000 milliseconds.
        Service port: 21604
        Stream count: 4
    Using libcam v1.0
    While cam-app-example is running on DomU1, start another instance on DomU2. cam-app-example has a mode to inject a fault to test the CAM framework. Run cam-app-example again from the DomU2 terminal with fault injection to event stream 0:
    cam-app-example -u 22085ddc-bc10-11ed-9a44-7ef9696e -t 2000 -c 5 -s 2 -f -S 0 -T 1000 -a 192.168.1.1
    Service port: 21604
    Stream count: 2
    Processing count: 5
Using libcam v1.0
As observed from the SI Cluster 1 terminal, cam-service is loading four stream deployment files from DomU1 and two stream deployment files from DomU2 for monitoring. In the following log, the stream messages are received and processed by it:
Init Message
Init Message
Init Message
Init Message
Start Message
Start Message
Start Message
Start Message
Event Message
Event Message
Event Message
Event Message
Connection 5 is created.
Init Message
Stream 22085ddc-bc10-11ed-9a44-7ef9696e0001 configuration is loaded.
Init Message
Stream 22085ddc-bc10-11ed-9a44-7ef9696e0000 configuration is loaded.
Start Message
Start Message
Event Message
Event Message
Event Message
ERROR:     stream_uuid: 2285ddc-bc10-11ed-9a44-7ef9696e0000
ERROR:     event_id: 0
ERROR:     time_expected: 1710275907816057
ERROR:     stream_uuid: 22085ddc-bc10-11ed-9a44-7ef9696e0000
ERROR:     timestamp: 1710275909816069
Note
  1. To leave the DomU1 console, type Ctrl-] and enter send esc.
  2. To leave the DomU2 console, type Ctrl-].
  3. To shut down the FVP and terminate the emulation automatically, follow the below steps:
    • Issue the following command on the Primary Compute terminal.
      shutdown now
      reboot: Power down
    • Close the tmux pane started for DomU2 by pressing Ctrl-d.
  4. Select Build.
The complete test suite takes around 65 minutes to complete. See Integration Tests Validating the Critical Application Monitoring Demo for more details.
RESULTS - test_40_cam.CAMTest.test_cam_app_example_to_service_on_si: PASSED (63.55s)
RESULTS - test_40_cam.CAMTest.test_cam_app_example_to_service_on_si_with_multiple_connections: PASSED (62.12s)
RESULTS - test_40_cam.CAMTest.test_cam_ptp_sync: PASSED (143.39s)
RESULTS - test_40_cam.CAMTest.test_cam_tool_deploy_to_si: PASSED (63.58s)
RESULTS - test_40_cam.CAMTest.test_cam_tool_pack: PASSED (62.96s)
RESULTS - test_40_cam.CAMTest.test_data_calibration: PASSED (175.01s)
RESULTS - test_40_cam.CAMTest.test_logical_check_on_si: PASSED (26.43s)
RESULTS - test_40_cam.CAMTest.test_temporal_check_on_si: PASSED (78.28s)
RESULTS - test_40_cam.CAMTestDomU2.test_cam_app_example_to_service_on_si: PASSED (60.84s)
RESULTS - test_40_cam.CAMTestDomU2.test_cam_app_example_to_service_on_si_with_multiple_connections: PASSED (63.07s)
RESULTS - test_40_cam.CAMTestDomU2.test_cam_ptp_sync: PASSED (13.27s)
RESULTS - test_40_cam.CAMTestDomU2.test_cam_tool_deploy_to_si: PASSED (32.96s)
RESULTS - test_40_cam.CAMTestDomU2.test_cam_tool_pack: PASSED (32.19s)
RESULTS - test_40_cam.CAMTestDomU2.test_data_calibration: PASSED (100.73s)
RESULTS - test_40_cam.CAMTestDomU2.test_logical_check_on_si: PASSED (25.67s)
RESULTS - test_40_cam.CAMTestDomU2.test_temporal_check_on_si: PASSED (77.41s)
RESULTS - test_40_cam.CAMTestMultiDom.test_cam_app_example_to_service_on_si_with_multiple_vms: PASSED (68.86s)
Note
The demo can be run on the Baremetal Architecture or Virtualization Architecture. See Safety Island Actuation Demo for further details.
Build
  1. Select Safety Island Actuation Demo from the Use-Case menu.
  3. Select Build.
Run the FVP
The user should wait for the system to boot and for the Linux prompt to appear. The following image shows an example on how the terminal should look after the fvp invocation.
Arm Auto Solutions Linux Login Prompt
The Safety Island (SI) Cluster 2 terminal running the Actuation Service is available via the tmux window titled terminal_uart_si_cluster2. For ease of navigation, it’s recommended to join the SI Cluster 2 terminal window to the Primary Compute terminal window and creating a tmux pane attached to the build host machine in order to issue commands on it.
  2. Press Ctrl-b % to add a new tmux pane which will be used to issue commands on the build host machine.
  3. Press Ctrl-b : and then type join-pane -s :terminal_uart_si_cluster2 followed by pressing Enter key to join the Actuation Service terminal window to the Primary Compute terminal window.
Arm Auto Solutions FVP Rearrange Windows
Run the Demo
  1. Run the ping command from the Primary Compute terminal (running Linux) to verify that it can communicate with the Safety Island Cluster 2 (running Zephyr):
    ping 192.168.2.1 -c 10
    The output should look like the following line, repeated 10 times:
    64 bytes from 192.168.2.1 seq=0 ttl=64 time=0.151 ms
  2. From the tmux pane started for the build host machine terminal, start the Packet Analyzer:
    cd ~/arm-auto-solutions/
    kas shell -c "oe-run-native packet-analyzer-native start_analyzer -L debug -a localhost -c ./data"
    The following messages are expected from the host terminal:
    INFO : analyzer_client.py/_connect_to: Starting analyze, use Ctrl-C to stop the process.
    INFO : analyzer_client.py/_connect_to: Attempting a connect to (localhost : 49152)
    INFO : analyzer_client.py/_connect_to: Successfully connected to (localhost : 49152)
    A message similar to the following should appear on the SI Cluster 2 terminal:
    Actuation Service initialized.
    Accepted tcp connection from the Packet Analyzer: <11>
    Refer to the following image for an invocation example of the Packet Analyzer.
    Arm Auto Solutions Packet Analyzer - Baremetal Architecture
  1. Start the Player on the Primary Compute terminal which replays a recording of a driving scenario:
    actuation_player -p /usr/share/actuation_player/
    A message similar to the following should appear on the Primary Compute terminal:
    Waiting for readers...     │1146571223376: -0.0000 (m/s^2) | 0.0000 (rad)
    ...Done. Starting replay.  │Thread get_analyzer_handle performing a blocking accept
    51572682601: -0.0000 (m/s^2) |  0.0000 (rad)
    51597466928: -0.0000 (m/s^2) |  0.0000 (rad)
    51622532911: -0.0000 (m/s^2) |  0.0000 (rad)
    51647642316: -0.0000 (m/s^2) |  0.0000 (rad)
    51672535849: -0.0000 (m/s^2) |  0.0000 (rad)
    51697376579: -0.0000 (m/s^2) |  0.0000 (rad)
    51722500414: -0.0000 (m/s^2) |  0.0000 (rad)
    51747622543: -0.0000 (m/s^2) |  0.0000 (rad)
    51772496466: -0.0000 (m/s^2) |  0.0000 (rad)
    A message similar to the following should appear on the host terminal where the Packet Analyzer is running:
    INFO : analyzer_client.py/run_analyze_on_chain: (1) Analyzer synced with packet chain
    The following messages should appear on the host terminal, but values may differ once the Packet Analyzer has finished running:
    INFO : analyzer_client.py/run_analyze_on_chain: All expected control packets received
    INFO : analyzer_client.py/_log_jitter: Observed Frequency = 21.36147200, Avg Jitter = 0.02624593, Std Deviation:0.06096328
    INFO : analyzer_client.py/run_analyze_on_chain: End of cycle: AnalyzerResult.SUCCESS
    INFO : analyzer_client.py/_tear_conn: Received fin ack from Actuation Service
    Chain ID   Result
    0          AnalyzerResult.SUCCESS
  2. To shut down the FVP and terminate the emulation automatically, follow the below steps:
      shutdown now
      reboot: Power down
    • Close the tmux pane started for the build host machine by pressing Ctrl-d.
  1. Select Safety Island Actuation Demo as Use-Case.
  4. Select Build.
The complete test suite takes around 45 minutes to complete. See Integration Tests Validating the Safety Island Actuation Demo for more details.
RESULTS - test_30_actuation.ActuationTest.test_analyzer_help: PASSED (0.44s)
RESULTS - test_30_actuation.ActuationTest.test_ping: PASSED (26.04s)
RESULTS - test_30_actuation.ActuationTest.test_player_to_analyzer: PASSED (167.15s)
Note
Build
  3. Select Build.
Run the FVP
The user should wait for the system to boot and for the Linux prompt to appear. On a Virtualization Architecture image, this will access the Dom0 terminal. The following image shows an example on how the terminal should look after the fvp invocation.
Note
Run the Demo
  1. Enter the DomU1 console using the xl tool:
    xl console domu1
  2. Run the ping command from the DomU1 terminal (running Linux) to verify that it can communicate with the Safety Island Cluster 2 (running Zephyr):
  3. From the tmux pane started for the build host machine terminal, start the Packet Analyzer:
    Arm Auto Solutions Packet Analyzer - Virtualization Architecture
  1. Start the Player on DomU1 which replays a recording of a driving scenario:
    The following messages should appear, but values may differ once the Packet Analyzer has finished running:
    Chain ID   Result
  2. To leave the DomU1 console, type Ctrl-] and enter send esc.
      shutdown now
      reboot: Power down
  4. Select Build.
The complete test suite takes around 110 minutes to complete. See Integration Tests Validating the Safety Island Actuation Demo for more details.
RESULTS - test_30_actuation.ActuationTest.test_analyzer_help: PASSED (0.40s)
RESULTS - test_30_actuation.ActuationTest.test_ping: PASSED (42.15s)
RESULTS - test_30_actuation.ActuationTest.test_player_to_analyzer: PASSED (265.77s)
Note
Safety Island Communication Demo (using HIPC)
The Safety Island Communication Demo uses HIPC (Heterogeneous Inter-processor Communication) to validate networking between the Primary Compute and the three Safety Island clusters.
Build
  1. Select Safety Island Communication Demo (using HIPC) from the Use-Case menu.
  3. Select Build.
  1. Select Safety Island Communication Demo (using HIPC) as Use-Case.
  4. Select Build.
The complete test suite takes around 45 minutes to complete. See Integration Tests Validating the Safety Island Communication Demo for more details.
RESULTS - test_30_hipc.HIPCTestBase.test_hipc_cluster0: PASSED (223.04s)
RESULTS - test_30_hipc.HIPCTestBase.test_hipc_cluster1: PASSED (351.62s)
RESULTS - test_30_hipc.HIPCTestBase.test_hipc_cluster2: PASSED (426.17s)
RESULTS - test_30_hipc.HIPCTestBase.test_hipc_cluster_cl0_cl1: PASSED (100.46s)
RESULTS - test_30_hipc.HIPCTestBase.test_hipc_cluster_cl0_cl2: PASSED (120.00s)
RESULTS - test_30_hipc.HIPCTestBase.test_hipc_cluster_cl1_cl2: PASSED (161.80s)
RESULTS - test_30_hipc.HIPCTestBase.test_ping_cl0_cl1: PASSED (37.34s)
RESULTS - test_30_hipc.HIPCTestBase.test_ping_cl0_cl2: PASSED (36.80s)
RESULTS - test_30_hipc.HIPCTestBase.test_ping_cl1_cl2: PASSED (37.10s)
RESULTS - test_30_hipc.HIPCTestBase.test_ping_cluster0: PASSED (102.31s)
RESULTS - test_30_hipc.HIPCTestBase.test_ping_cluster1: PASSED (95.50s)
RESULTS - test_30_hipc.HIPCTestBase.test_ping_cluster2: PASSED (92.91s)
RESULTS - test_30_ptp.PTPTest.test_ptp_linux_services: PASSED (4.56s)
RESULTS - test_30_ptp.PTPTest.test_ptp_si_clients: PASSED (34.73s)
Note
Build
  3. Select Build.
  4. Select Build.
The complete test suite takes around 90 minutes to complete. See Integration Tests Validating the Safety Island Communication Demo for more details.
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_hipc_cluster0: PASSED (311.77s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_hipc_cluster1: PASSED (389.55s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_hipc_cluster2: PASSED (413.83s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_hipc_cluster_cl0_cl1: PASSED (114.97s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_hipc_cluster_cl0_cl2: PASSED (138.32s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_hipc_cluster_cl1_cl2: PASSED (182.33s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_ping_cl0_cl1: PASSED (60.64s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_ping_cl0_cl2: PASSED (61.63s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_ping_cl1_cl2: PASSED (61.06s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_ping_cluster0: PASSED (153.76s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_ping_cluster1: PASSED (154.39s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU1.test_ping_cluster2: PASSED (153.34s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU2.test_hipc_cluster1: PASSED (365.17s)
RESULTS - test_30_hipc_virtualization.HIPCTestDomU2.test_ping_cluster1: PASSED (152.43s)
RESULTS - test_30_ptp_virtualization.PTPTestDom0.test_ptp_linux_services: PASSED (7.17s)
RESULTS - test_30_ptp_virtualization.PTPTestDom0.test_ptp_si_clients: PASSED (50.57s)
RESULTS - test_30_ptp_virtualization.PTPTestDomU1.test_ptp_domu_client: PASSED (47.37s)
RESULTS - test_30_ptp_virtualization.PTPTestDomU1.test_ptp_linux_services: PASSED (7.17s)
RESULTS - test_30_ptp_virtualization.PTPTestDomU2.test_ptp_domu_client: PASSED (50.57s)
RESULTS - test_30_ptp_virtualization.PTPTestDomU2.test_ptp_linux_services: PASSED (47.37s)
Note
Parsec-enabled TLS Demo
The demo can be run on the Baremetal Architecture. It consists of a TLS server and a TLS client application.
Refer to Parsec-enabled TLS Demo for more information on this application. This demo is included as part of the Safety Island Actuation Demo.
Build
  3. Select Build.
Run the FVP
Run the Demo
The demo consists of a TLS server and a TLS client application.
  1. Run ssl_server from the Primary Compute terminal in the background and press the Enter key to continue:
    ssl_server &
    A message similar to the following should appear:
    . Seeding the random number generator... ok
    . Loading the server cert. and key... ok
    . Bind on https://localhost:4433/ ... ok
    . Setting up the SSL data.... ok
    . Waiting for a remote connection ...
    The TLS client application can take an optional parameter as the TLS server IP address. The default value of the parameter is localhost.
  2. Run ssl_client1 from the Primary Compute terminal in a container:
    docker run  --rm -v /run/parsec/parsec.sock:/run/parsec/parsec.sock -v /usr/bin/ssl_client1:/usr/bin/ssl_client1 --network host docker.io/library/ubuntu:22.04 ssl_client1
    After a few seconds, a message similar to the following should appear:
    Trying to pull docker.io/library/ubuntu:22.04...
    Getting image source signatures
    Copying blob a186900671ab done   |
    Copying config 981912c48e done   |
    Writing manifest to image destination
       . Loading the CA root certificate ... ok (0 skipped)
       . Connecting to tcp/localhost/4433... ok
       . Performing the SSL/TLS handshake... ok
       . Setting up the SSL/TLS structure... ok
       < Read from client: 18 bytes read
    GET / HTTP/1.0
       > Write to client: 156 bytes written
    HTTP/1.0 200 OK
    Content-Type: text/html
    <h2>Mbed TLS Test Server</h2>
    <p>Successful connection using: TLS-ECDHE-RSA-WITH-CHACHA20-POLY1305-SHA256</p>
     ok
      . Verifying peer X.509 certificate... ok
      > Write to server:  . Closing the connection... ok
     18 bytes written
    GET / HTTP/1.0
      < Read from server:  . Waiting for a remote connection ... 156 bytes read
    HTTP/1.0 200 OK
  3. Stop the TLS server and synchronize the container image to the persistent storage:
    pkill ssl_server
    sync
  4. To shut down the FVP and terminate the emulation automatically, issue the following command on the Primary Compute terminal.
    shutdown now
    reboot: Power down
For more details about the validation of Parsec demo, refer to Integration Tests Validating the Parsec-enabled TLS Demo.
  4. Select Build.
The complete test suite takes around 45 minutes to complete. See Integration Tests Validating the Parsec-enabled TLS Demo for more details.
RESULTS - test_40_parsec.ParsecTest.test_parsec_demo: PASSED (479.25s)
Note
Primary Compute PSA Secure Storage and Crypto APIs Architecture Test Suite
Refer to Primary Compute Secure Services for more information on this application. This demo is included as part of the Critical Application Monitoring Demo.
Build
  2. Select Baremetal from the Reference Stack Architecture menu.
  3. Select Build.
Run the FVP
Run the Demo
The demo consists of simple tests run from the Linux terminal.
  1. Run the PSA Crypto API tests from the Primary Compute terminal using the following command:
    psa-crypto-api-test
    A message similar to the following should appear once the tests have completed:
    ************ Crypto Suite Report **********
    TOTAL TESTS     : 59
    TOTAL PASSED    : 59
    TOTAL SIM ERROR : 0
    TOTAL FAILED    : 0
    TOTAL SKIPPED   : 0
  2. Run the PSA Protected Storage API tests from the Primary Compute terminal using the following command:
    psa-ps-api-test
    ************ Storage Suite Report **********
    TOTAL TESTS     : 17
    TOTAL PASSED    : 11
    TOTAL SIM ERROR : 0
    TOTAL FAILED    : 0
    TOTAL SKIPPED   : 6
  3. Run the PSA Internal Trusted Storage API tests from the Primary Compute terminal using the following command:
    psa-its-api-test
    TOTAL TESTS     : 10
    TOTAL PASSED    : 10
    TOTAL SIM ERROR : 0
    TOTAL FAILED    : 0
    TOTAL SKIPPED   : 0
    shutdown now
    reboot: Power down
For more details about the validation of PSA Architecture Test Suite, refer to Integration Tests Validating Primary Compute PSA APIs Architecture Test Suite.
  4. Select Build.
The complete test suite takes around 40 minutes to complete. See Integration Tests Validating Primary Compute PSA APIs Architecture Test Suite for more details.
RESULTS - test_50_trusted_services.ArmAutoSolutionsTrustedServices.test_03_psa_crypto_api_test: PASSED (298.70s)
RESULTS - test_50_trusted_services.ArmAutoSolutionsTrustedServices.test_04_psa_its_api_test: PASSED (17.47s)
RESULTS - test_50_trusted_services.ArmAutoSolutionsTrustedServices.test_05_psa_ps_api_test: PASSED (68.88s)
Note
Safety Island PSA Secure Storage APIs Architecture Test Suite
The demo can be run on the Baremetal Architecture. See Safety Island PSA Architecture Test Suite for further details.
Build
  1. Select Safety Island PSA Secure Storage APIs Architecture Test Suite from the Use-Case menu.
  2. Select Build.
Run the FVP
To start the FVP:
The Safety Island Cluster 2 terminal running the PSA Secure Storage APIs Architecture Test Suite is available via the tmux window titled terminal_uart_si_cluster2.
The Safety Island Cluster 2 tmux window can be accessed by typing Ctrl-b w, using the arrow keys to select terminal_uart_si_cluster2 then pressing the Enter key.
Run the Demo
The tests will automatically run. A log similar to the following should be visible; it is normal for some tests to be skipped but there should be no failed tests:
***** PSA Architecture Test Suite - Version 1.4 *****
Running.. Storage Suite
TEST: 401 | DESCRIPTION: UID not found check | UT: STORAGE
[Info] Executing tests from non-secure
[Info] Executing ITS Tests
[Check 1] Call get API for UID 6 which is not set
[Check 2] Call get_info API for UID 6 which is not set
[Check 3] Call remove API for UID 6 which is not set
[Check 4] Call get API for UID 6 which is removed
[Check 5] Call get_info API for UID 6 which is removed
[Check 6] Call remove API for UID 6 which is removed
Set storage for UID 6
[Check 7] Call get API for different UID 5
[Check 8] Call get_info API for different UID 5
[Check 9] Call remove API for different UID 5
[Info] Executing PS Tests
TEST RESULT: PASSED
<further tests removed from log for brevity>
TOTAL TESTS     : 17
TOTAL PASSED    : 11
TOTAL SIM ERROR : 0
TOTAL FAILED    : 0
TOTAL SKIPPED   : 6
Note
This use-case does not require waiting for the Primary Compute to boot.
To shut down the FVP and terminate the emulation, select the terminal titled as python3 where the runfvp was launched by pressing Ctrl-b 0 and press Ctrl-c to stop the FVP process.
  2. Select Run Automated Validation from the Runtime Validation Setup menu.
  3. Select Build.
The complete test suite takes around 15 minutes to complete. See Integration Tests Validating Safety Island PSA APIs Architecture Test Suite for more details.
The following message is expected in the output to validate this Use-Case:
RESULTS - test_10_si_psa_arch_tests.SIPSAArchTests.test_psa_si_cluster2: PASSED (0.00s)
Note
Safety Island PSA Crypto APIs Architecture Test Suite
Build
  1. Select Safety Island PSA Crypto APIs Architecture Test Suite from the Use-Case menu.
  2. Select Build.
Run the FVP
To start the FVP:
The PSA Crypto APIs Architecture Test Suite is deployed on all the 3 Safety Island (SI) Clusters. The test results can be seen on the following tmux windows:
  • terminal_uart_si_cluster0
  • terminal_uart_si_cluster1
  • terminal_uart_si_cluster2
The user can navigate through the windows mentioned above by pressing Ctrl-b w and arrow keys followed by the Enter key.
Run the tests
The tests will automatically run after the FVP is started. The complete test suite takes around 5 minutes to complete. When the tests finish, a log similar to the following should be visible. Normally no failure should be seen:
TOTAL TESTS     : 61
TOTAL PASSED    : 61
TOTAL SIM ERROR : 0
TOTAL FAILED    : 0
TOTAL SKIPPED   : 0
Note
  3. Select Build.
The complete test suite takes around 35 minutes to complete. See Integration Tests Validating Safety Island PSA APIs Architecture Test Suite for more details.
RESULTS - test_10_si_psa_arch_tests.SIPSAArchTests.test_psa_si_cluster0: PASSED (0.01s)
RESULTS - test_10_si_psa_arch_tests.SIPSAArchTests.test_psa_si_cluster1: PASSED (0.01s)
RESULTS - test_10_si_psa_arch_tests.SIPSAArchTests.test_psa_si_cluster2: PASSED (0.01s)
Note
Fault Management Demo
The demo uses the Safety Island Cluster 1 console and it can be run on the Baremetal Architecture of the Safety Island Actuation Demo.
Refer to Fault Management for further details.
Build
To build the Baremetal Architecture image:
  3. Select Build.
Run the FVP
To start the FVP:
The Fault Management subsystem is deployed on Safety Island Cluster 1 so the instructions below should be executed on its terminal.
The Safety Island Cluster 1 tmux window can be accessed by typing Ctrl-b w, using the arrow keys to select terminal_uart_si_cluster1 then pressing the Enter key.
Run the Demo
The instructions below demonstrate injecting faults into both the System FMU and GIC-720AE FMU and how this affects the SSU safety state.
  1. Start by enumerating the configured fault device tree:
    fault tree
    The output shows the root fault device fmu@2a510000 (the System FMU), after which are the attached safety state device ssu@2a500000, the fault device fmu@2a570000 (the Primary Compute GIC-720AE FMU) and the fault device fmu@2a530000 (the Safety Island GIC-720AE FMU):
    Root 0: fmu@2a510000
            Safety: ssu@2a500000
            Slot 0: fmu@2a570000
            Slot 1: fmu@2a530000
  2. After booting, query the initial state of the SSU:
    fault safety_status ssu@2a500000
    The initial state is TEST:
    Status: TEST (0x0)
  3. It is expected that a Fault Management deployment would perform a self-test after boot then signal its outcome to the SSU. For demonstration purposes, simulate a successful self-test completion by issuing the compl_ok signal to the SSU:
    fault safety_control ssu@2a500000 compl_ok
    The system is now SAFE for operation:
    Signal: compl_ok (0x0)
    State: SAFE (0x3)
  4. Simulate an internal Lockstep error (0x4) in the System FMU:
    fault inject fmu@2a510000 0x4
    Three events are logged:
    • The subsystem reports that it received the fault and that it was non-critical (all System FMU internal faults are non-critical).
    • The safety component reports that this caused the SSU to enter the ERRN state.
    • The storage component reports that the total historical fault count for this fault on this device is now 1.
    Injecting fault 0x4 to device fmu@2a510000
    [00:04:49.110,000] <inf> fault_mgmt: Fault received (non-critical): 0x4 on fmu@2a510000
    [00:04:49.110,000] <inf> fault_mgmt_safety: Safety status: ERRN (0x5) on ssu@2a500000
    [00:04:49.160,000] <inf> fault_mgmt_protected_storage: Fault count for 0x4 on fmu@2a510000: 1
  5. The SSU will remain in the ERRN state until signaled (unless a critical fault occurs). Send a compl_ok signal again to recover from this fault:
    The SSU is now in the SAFE state again:
    State: SAFE (0x3)
  6. Next, inject an SPI collator external error (0x20000a00) into the GIC-720AE FMU:
    fault inject fmu@2a570000 0x20000a00
    This results in a similar output to above, except that the received fault was critical and the safety status is now ERRC. (GIC-720AE FMU faults are critical by default, but this can be changed from the shell using the fault set_critical sub-command).
    Injecting fault 0x20000a00 to device fmu@2a570000
    [00:09:13.210,000] <inf> fault_mgmt: Fault received (critical): 0x20000a00 on fmu@2a570000
    [00:09:13.210,000] <inf> fault_mgmt_safety: Safety status: ERRC (0x6) on ssu@2a500000
    [00:09:13.270,000] <inf> fault_mgmt_protected_storage: Fault count for 0x20000a00 on fmu@2a570000: 1
  7. The number of occurrences of each fault is tracked per device by the storage component. Inject another Lockstep error into the System FMU:
    The fault count is now 2. Note that the safety status is still ERRC.
    [00:14:02.800,000] <inf> fault_mgmt: Fault received (non-critical): 0x4 on fmu@2a510000
    [00:14:02.800,000] <inf> fault_mgmt_safety: Safety status:  ERRC (0x6) on ssu@2a500000
    [00:14:02.860,000] <inf> fault_mgmt_protected_storage: Fault count for 0x4 on fmu@2a510000: 2
    The full list of stored faults can also be queried:
    fault list
    This shows all the faults injected into both FMUs above:
    Fault history:
    Fault received (non-critical): 0x4 on fmu@2a510000 : count 2
    Fault received (critical): 0x20000a00 on fmu@2a570000 : count 1
  8. The ERRC represents a critical system failure and cannot be recovered by the software - confirm this by trying to issue compl_ok again:
    The SSU status is still ERRC:
    State: ERRC (0x6)
    The state can now only be affected through a full system reset (e.g. by stopping and starting the FVP), after which the state will be TEST once again.
Note
  1. To shut down the FVP and terminate the emulation, select the terminal titled as python3 where the runfvp was launched by pressing Ctrl-b 0 and press Ctrl-c to stop the FVP process.
See the Shell Reference for more details about these and other Fault Management shell sub-commands.
  4. Select Build.
The complete test suite takes around 45 minutes to complete. See Integration Tests Validating the Fault Management Subsystem for more details.
RESULTS - test_10_fault_mgmt.FaultMgmtSSUTest.test_gic_fmu_ssu_compl_ok: PASSED (96.24s)
RESULTS - test_10_fault_mgmt.FaultMgmtSSUTest.test_ssu_ce_not_ok: PASSED (38.18s)
RESULTS - test_10_fault_mgmt.FaultMgmtSSUTest.test_ssu_nce_ok: PASSED (29.24s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_fmu_fault_clear: PASSED (11.24s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_fmu_fault_count: PASSED (6.04s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_fmu_fault_list: PASSED (36.22s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_fmu_fault_summary: PASSED (22.64s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_gic_fmu_inject: PASSED (18.69s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_system_fmu_internal_inject: PASSED (8.77s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_system_fmu_internal_set_enabled: PASSED (11.09s)
RESULTS - test_10_fault_mgmt.FaultMgmtTest.test_tree: PASSED (0.71s)
Note
Arm SystemReady IR Validation
Arm SystemReady IR Firmware Build
The Arm SystemReady IR Firmware Build option just builds the Arm SystemReady IR-aligned firmware.
Refer to Arm SystemReady IR for more details.
Arm Auto Solutions Build Configuration Menu - Arm SystemReady IR Firmware Build
Build
To build the Arm SystemReady IR-aligned firmware image:
  1. Select Arm SystemReady IR Firmware Build under Arm SystemReady IR Validation from the Use-Case menu.
  2. Select Build.
The firmware images listed below can be found in the directory build/tmp_systemready-glibc/deploy/images/fvp-rd-kronos/.
  • ap-flash-image.img
  • encrypted_cm_provisioning_bundle_0.bin
  • encrypted_dm_provisioning_bundle.bin
  • rse-flash-image.img
  • rse-nvm-image.img
  • rse-rom-image.img
Arm SystemReady IR Architecture Compliance Suite (ACS) Tests
The ACS for the Arm SystemReady IR certification is delivered through a live OS image, which enables the basic automation to run the tests.
The system will boot with the ACS live OS image and the ACS tests will run automatically after the system boots. See Arm SystemReady IR ACS Tests for more details.
Build and Automated Validation
To build and run the Arm SystemReady IR ACS tests:
  1. Select Arm SystemReady IR Architecture Compliance Suite (ACS) Tests under Arm SystemReady IR Validation from the Use-Case menu.
  2. Select Build.
A similar output to the following is printed out:
NOTE: recipe arm-systemready-ir-acs-2.1.0-r0: task do_testimage: Started
Creating terminal default on terminal_ns_uart0
Creating terminal tf-a on terminal_sec_uart
Creating terminal scp on terminal_uart_scp
Creating terminal rse on terminal_rse_uart
Creating terminal safety_island_c0 on terminal_uart_si_cluster0
Creating terminal safety_island_c1 on terminal_uart_si_cluster1
Creating terminal safety_island_c2 on terminal_uart_si_cluster2
ACS SIE + bbr/bsa running
Test Group (VariableAttributes): PASSED
Test Group (VariableUpdates): FAILED
Test Group (AuthVar_Conf): FAILED
Test Group (AuthVar_Func): FAILED
Test Group (BBSRVariableSizeTest_func): FAILED
Test Group (ImageLoading): FAILED
Test Group (PlatformSpecificElements): FAILED
Test Group (RequiredElements): FAILED
Test Group (CheckEvent_Conf): PASSED
Test Group (CheckEvent_Func): PASSED
Test Group (CloseEvent_Func): PASSED
Test Group (CreateEventEx_Conf): PASSED
Test Group (CreateEventEx_Func): PASSED
Test Group (CreateEvent_Conf): PASSED
Test Group (CreateEvent_Func): PASSED
Test Group (RaiseTPL_Func): PASSED
Test Group (RestoreTPL_Func): PASSED
Test Group (SetTimer_Conf): PASSED
Test Group (SetTimer_Func): PASSED
Test Group (SignalEvent_Func): PASSED
Test Group (WaitForEvent_Conf): PASSED
Test Group (WaitForEvent_Func): PASSED
Test Group (AllocatePages_Conf): PASSED
Test Group (AllocatePages_Func): PASSED
Test Group (AllocatePool_Conf): PASSED
Test Group (AllocatePool_Func): PASSED
Test Group (FreePages_Conf): PASSED
Test Group (FreePages_Func): PASSED
Test Group (GetMemoryMap_Conf): PASSED
Test Group (GetMemoryMap_Func): PASSED
Capsule update test succeeded
Transitioned to off
RESULTS:
RESULTS - arm_systemready_ir_acs.SystemReadyACSTest.test_acs: PASSED (17074.54s)
RESULTS - arm_systemready_ir_acs_capsule_update.SystemReadyACSCapsuleUpdateTest.test_capsule_update: PASSED (229.49s)
RESULTS - arm_systemready_ir_acs_shutdown.SystemReadyACSShutdownTest.test_shutdown: PASSED (15.17s)
SUMMARY:
arm-systemready-ir-acs () - Ran 3 tests in 17327.711s
arm-systemready-ir-acs - OK - All required tests passed (successes=3, skipped=0, failures=0, errors=0)
As seen in the above logs, some Test Groups are expected to fail. The following messages are expected to validate this Use-Case:
Note
Running the ACS tests more than once will have them resume from where they last stopped. Additionally, consecutive runs are not supported by the ACS logs; it will result in a failure after the end of the tests. To run the ACS tests again, use the following to refresh the firmware images in flash and re-start the entire ACS test suite properly:
kas shell -c "bitbake arm-systemready-ir-acs -C unpack"
Note
The ACS tests take hours to complete. The actual time taken will vary depending on the performance of the build host. The default timeout setting for the tests is 12 hours for an x86_64 host or 24 hours for an aarch64 host. If a timeout failure occurs, increase the timeout setting and re-run the tests with the following command on the build host terminal. The example command below changes the timeout setting to 16 hours.
TEST_OVERALL_TIMEOUT="\${@16*60*60}" kas shell -c "bitbake arm-systemready-ir-acs -C unpack"
Note
Refer to Arm SystemReady IR ACS Tests for an explanation on how the ACS tests are set up and how they work in the Reference Software Stack.
Linux Distribution Installation (Debian, openSUSE and Fedora)
The Arm SystemReady IR-aligned firmware must boot at least three unmodified generic UEFI distribution images from an ISO image.
This Software Stack currently supports three Linux distributions: Debian Stable, openSUSE Leap and Fedora Server.
Note
Arm SystemReady IR ACS Tests runs the SIE tests, which enrolls the authenticated variables for UEFI Secure Boot, so running the Linux distros installation after running the ACS tests will result in a failure. The firmware flash images need to be recreated with the following command:
Refer to UEFI Secure Boot for more information.
Note
The manual installation of a Linux distribution requires some manual interaction, for example, some necessary selections or confirmations, entering the user and password, etc.
The whole installation process takes a long time (possibly up to 10 hours, or even longer).
We suggest that when running the Linux distribution installations the FVP is the only running process as it will consume large amounts of RAM that can make the system unstable.
Refer to Linux Distributions Installation Tests for an explanation on how the Linux distros installation is set up and how they work in the Reference Software Stack.
Debian
Distro Unattended Installation
Not supported in the current release.
Distro Manual Installation
To install Debian, you can refer to the Debian GNU/Linux Installation Guide.
Distro Installation Media Preparation
To build the Arm SystemReady IR Linux distros installation tests:
  1. Select Debian Linux Distro Installation under Linux Distribution Installation (Debian, openSUSE and Fedora) from the Use-Case menu.
  2. Select Build.
Arm Auto Solutions Build Configuration Menu - Debian Linux Distro Installation
Distro Installation
Run the following command to start the installation:
The whole process of installing Debian will probably take about 5 hours. The install process begins when you see the following:
Grub Install Options Menu - Debian Linux Distro Installation
Select Install to start the installation process.
The following is the problem that has been encountered during the Debian installation process and how to solve it:
  • Install the GRUB boot loader
    When the installation reaches the Install the GRUB boot loader phase, choose Yes.
    Grub Installation Prompt - Debian Linux Distro Installation
There will be an error Unable to install GRUB in dummy. This is because on an EBBR platform, UEFI SetVariable() is not required at runtime (however, it is required at boot time).
Grub Installation Failure Prompt - Debian Linux Distro Installation
One workaround we have is to “execute a shell” when the GRUB install phase throws the above error. To execute a shell, press Ctrl-a n to switch the debug shell, and run the following commands:
chroot /target
update-grub
cp -v /boot/efi/EFI/debian/grubaa64.efi /boot/efi/EFI/BOOT/bootaa64.efi
A snapshot is as below:
Grub Workaround Console Output - Debian Linux Distro Installation
After doing the above GRUB workaround, press Ctrl-a p to go back to the installer again. Select Continue on the GRUB failure screen.
Second Grub Installation Failure Prompt - Debian Linux Distro Installation
Select Continue without boot loader in the Debian installer main menu and continue.
Debian Installer Main Menu - Debian Linux Distro Installation
  • Log in
    When the installation reaches the final Finishing the installation phase, you will need to wait some time to finish the remaining tasks, and then it will automatically reboot into the installed OS. You can log into the Linux shell with the user created during installation.
  • Terminate the FVP
    To shut down the FVP and terminate the emulation automatically, log into the Linux shell as the root user then run the following command.
    shutdown now
    The below message indicates the shutdown process is complete.
    reboot: Power down
    Subsequently running the FVP will boot into Debian.
openSUSE
In this test we have modified the installation ISO image to add the automatic installation file inside it. This required adding the autoinst.xml file inside the ISO image to locate the installation configuration file (yocto/kas/patches/meta-arm-systemready/0001-arm-systemready-linux-distros-Implement-unattended-o.patch)
Distro Installation
  1. Select openSUSE Linux Distro Installation under Linux Distribution Installation (Debian, openSUSE and Fedora) from the Use-Case menu.
  2. Select Build.
Arm Auto Solutions Build Configuration Menu - openSUSE Linux Distro Installation
A similar output to the following indicates when the installation is finished, which will take around 12 hours:
Transitioned to on
Installation status: Loading the kernel, initrd and basic drivers...
Installation status: Starting hardware detection...
Installation status: Loading Installation System...
Installation status: Performing Installation...
Installation status: Finishing Configuration...
Installation status: openSUSE installation finished successfully.
Transitioned to off
RESULTS:
RESULTS - arm_systemready_opensuse_unattended.SystemReadyOpenSUSEUnattendedTest.test_opensuse_unattended: PASSED (24367.99s)
SUMMARY:
arm-systemready-linux-distros-opensuse () - Ran 1 test in 24367.997s
  • Log in
    After the installation is finished, run the following command to log into the Linux shell:
    Log into the Linux shell with the user created during the installation using the username user and the password unsafe.
  • Terminate the FVP
    To shut down the FVP and terminate the emulation automatically, run the following command.
    sudo shutdown now
    reboot: Power down
    Subsequently running the FVP will boot into openSUSE.
To install openSUSE, you can refer to the openSUSE Installation Guide.
  2. Unselect Run Unattended Installation under Distros Unattended Installation Setup menu.
  3. Select Build.
The whole process of installing openSUSE will take several hours. The install process begins when you see the following:
Leap Install Options Menu - openSUSE Linux Distro Installation
Select No when you get to the Online Repositories screen.
Online Repositories Options Menu - openSUSE Linux Distro Installation
Select Installation to start the installation process.
  • System Role
    When you get to the System Role screen, select Server, then select Next to continue with the installation.
    System Role Selection Menu - openSUSE Linux Distro Installation
    Tip
    Use Tab to cycle through options on screens during installation.
  • Installation process
    Once you have selected Install on the Confirm Installation screen, the installation will proceed and it will take several hours. The steps of the installation process are:
    • Installing Packages...
    • Save configuration
    • Save installation settings
    • Install boot manager
    • Prepare system for initial boot
    • Then the system will reboot automatically in 10s, you can select OK to reboot immediately.
  • Log in
    After the reboot process, log into the Linux shell with the user created during installation.
  • Terminate the FVP
    sudo shutdown now
    reboot: Power down
Fedora
In this test we have modified the installation ISO image to add the kickstart configuration file inside it. This required editing the grub.cfg file inside the ISO image to locate the kickstart configuration file (meta-arm-systemready/recipes-test/arm-systemready-linux-distros/unattended-boot-conf/Fedora/ks.cfg).
Distro Installation
  1. Select Fedora Linux Distro Installation under Linux Distribution Installation (Debian, openSUSE and Fedora) from the Use-Case menu.
  2. Select Build.
Arm Auto Solutions Build Configuration Menu - Fedora Linux Distro Installation
Transitioned to on
Installation status: Loading the installer, kernel and initrd...
Installation status: Setting up the installation environment...
Installation status: Installing the software packages...
Installation status: Fedora installation finished successfully.
Transitioned to off
RESULTS:
RESULTS - arm_systemready_fedora_unattended.SystemReadyFedoraUnattendedTest.test_fedora_unattended: PASSED (38743.47s)
SUMMARY:
arm-systemready-linux-distros-fedora () - Ran 1 test in 38743.478s
  • Log in
  • Terminate the FVP
    sudo shutdown now
    reboot: Power down
    Subsequently running the FVP will boot into Fedora.
To install Fedora, you can refer to the Fedora Installation Guide.
  3. Select Build.
Distro Installation
The whole process of installing Fedora will probably take about 24 hours. The install process begins when you see the following:
Grub Install Options Menu - Fedora Linux Distro Installation
Select Install Fedora 39 to start the installation process.
Here are some tips for installing Fedora:
  1. It will take a few minutes for GRUB to load the installer, kernel and initrd.
  2. Once the installer has started, enter 2 to choose Use text mode.
    Starting installer, one moment...
    anaconda 39.32.6-2.fc39 for Fedora 39 started.
     * installation log files are stored in /tmp during the installation
     * shell is available on TTY2 and in second TMUX pane (ctrl+b, then press 2)
     * when reporting a bug add logs from /tmp as separate text/plain attachments
    X or window manager startup failed, falling back to text mode.
    X was unable to start on your machine. Would you like to start VNC to connect to
    this computer from another computer and perform a graphical installation or
    continue with a text mode installation?
    1) Start VNC
    2) Use text mode
    Please make a selection from the above ['c' to continue, 'h' to help, 'q' to
    quit, 'r' to refresh]: 2
  3. When reaching the installation menu, you will see several items marked as ! which indicates that the item needs to be configured before proceeding.
    Installation
    1) [x] Language settings                 2) [x] Time settings
           (English (United States))                (America/Chicago timezone)
    3) [!] Installation source               4) [!] Software selection
           (Setting up installation                 (Processing...)
           source...)
    5) [!] Installation Destination          6) [x] Network configuration
           (Processing...)                          (Connected: eth0)
    7) [!] Root password                     8) [!] User creation
           (Root account is disabled)               (No user will be created)
    Please make a selection from the above ['b' to begin installation, 'h' to help,
    'q' to quit, 'r' to refresh]:
    For 3) [!] Installation source, enter 3, then 1 to select CD/DVD.
    Installation source
    Choose an installation source type.
    1) CD/DVD
    2) local ISO file
    3) Network
    quit, 'r' to refresh]: 1
    For 4) [!] Software selection, enter 4, then c to continue.
    For 5) [!] Installation Destination, enter 5, then c to select the default options.
    For 6) [!] Network configuration, it will automatically change to x.
    For 7) [!] Root password, follow the prompts to enter the password and confirm.
    After entering root password, 8) [ ] User creation becomes optional and can be skipped.
    The final configuration should now appear as follows:
    Installation
    3) [x] Installation source               4) [x] Software selection
           (Local media)                            (Fedora Server Edition)
    5) [x] Installation Destination          6) [x] Network configuration
           (Automatic partitioning                  (Connected: eth0)
           selected)
    7) [x] Root password                     8) [ ] User creation
           (Root password is set)                   (No user will be created)
    Now enter b to start the installation.
  4. The installer is expected to stay at Configuring kernel-core.aarch64 for several hours. The installer will then verify the installed packages and continue to install the boot loader.
  5. The following error is expected while installing the boot loader. Ignore the error by responding yes and continue.
    Installing boot loader
    Question
    The following error occurred while installing the boot loader. The system will
    not be bootable. Would you like to ignore this and continue with installation?
    Failed to set new efi boot target. This is most likely a kernel or firmware bug.
    Please respond 'yes' or 'no': yes
    [anaconda]1:main* 2:shell  3:log  4:storage-log >Switch tab: Alt+Tab | Help: F1
  • Log in
    When the installation reaches the final Finishing the installation phase, you will need to wait some time to finish the remaining tasks. Once you see the message Installation complete. Press ENTER to quit:, you need to press enter to reboot into the installed OS. You can log into the Linux shell with the user created during installation.
  • Terminate the FVP
    shutdown now
    reboot: Power down
Secure Firmware Update
The firmware update is on-disk to meet Arm SystemReady IR requirements.
Build
The firmware update capsule for testing will be generated together with the image for the software stack when building. The firmware capsule is placed on a removable storage device (in the case of Arm FVPs, an MMC card implementation).
To run the configuration menu:
kas menu sw-ref-stack/Kconfig
  3. Select Build.
Run the FVP
Note that the main tmux windows involved in the Secure Firmware Update are terminal_ns_uart0 and terminal_rse_uart. For ease of navigation, it is recommended to join these in a single window with two panes.
  1. Ensure that the tmux window titled terminal_ns_uart0 is selected. If not, press Ctrl-b w from the tmux session, navigate to the tmux window titled terminal_ns_uart0 followed by pressing the Enter key.
  2. Press Ctrl-b : and then type join-pane -s :terminal_rse_uart -h followed by pressing the Enter key to join the RSE terminal window to the Primary Compute terminal window.
Arm Auto Solutions Secure Firmware Update Baremetal FVP Windows
The Reference Software Stack running on the Primary Compute can be logged into as the root user without a password in the Linux terminal. Run the below command to guarantee that all the expected services have been initialized.
Run the Demo
  1. To start the Secure Firmware Update, run the following commands to create the UpdateCapsule directory and copy the update capsule into it, followed by a reboot.
    mount /dev/vda1 /boot
    mount /dev/mmcblk0p1 /mnt
    mkdir -p /boot/EFI/UpdateCapsule
    cp -f /mnt/fw.cap /boot/EFI/UpdateCapsule
    reboot
    The system will begin the firmware update automatically. The following logs indicate that the upgrade process has started and is in progress.
    In terminal_ns_uart0:
    FF-A driver 1.0
    FF-A framework 1.0
    FF-A versions are compatible
    EFI: MM partition ID 0x8003
    EFI: FVP: Capsule shared buffer at 0x81000000 , size 8192 pages
    In terminal_rse_uart:
    [INF]:[FWU]: get_fwu_agent_state: enter, boot_index = 0
    [INF]:[FWU]: FMP image update: image id = 1
    [INF]:[FWU]: FMP image update: status = 0, version=7, last_attempt_version=0.
    [INF]: [FWU]: Host acknowledged.
    [INF]:[FWU]: pack_image_info:207 ImageInfo size = 105, ImageName size = 14, ImageVersionName size = 14
    [INF]: [FWU]: Getting image info succeeded.
    [INF]:[FWU]: uefi_capsule_retrieve_images: enter, capsule ptr = 0x0x65000000
    [INF]:[FWU]: uefi_capsule_retrieve_images: capsule size = 18284656, image count = 1
    [INF]:[FWU]: uefi_capsule_retrieve_images: image 0, version = 3
    [INF]:[FWU]: uefi_capsule_retrieve_images: image 0 at 0x65000070, size=18284560
    [INF]:[FWU]: flash_rss_capsule: enter: image = 0x65000070, size = 16187408, version = 3
    [INF]:[FWU]: erase_bank: erasing sectors = 4080, from offset = 16748544
    [INF]:[FWU]: flash_rss_capsule: writing capsule to the flash at offset = 16748544...
    Note
    This step will take about 10 minutes.
  2. The system will reset after a successful firmware update and boot with the updated firmware. This can be confirmed by checking the terminal logs; if there are lines in the log like below, then the upgrade was successful and the system has successfully rebooted with the updated firmware.
    [INF]: [FWU]: Flashing the image succeeded.
    [INF]: [FWU]: Performing system reset...
    [INF]:[FWU]: get_fwu_agent_state: enter, boot_index = 1
    Note
    The following error messages will appear in the logs:
    [ERR]:[FWU]: flash_rss_capsule: version error
    [ERR]:[FWU]: flash_fip_capsule: version error
    [ERR]: [FWU]: Flashing the image Failed.
    These errors are expected. As long as you scroll upwards and see the aforementioned lines then the update was successful.
  3. The system will eventually boot into Linux using the upgraded firmware.
  4. To shut down the FVP and terminate the emulation automatically, follow the below steps:
      shutdown now
      reboot: Power down
  2. Select Baremetal from the Reference Software Stack Architecture menu.
  4. Select Build.
RESULTS - test_00_fwu.SecureFirmwareUpdateTest.test_securefirmwareupdate: PASSED (414.85s)
Note
See Integration Tests Validating Secure Firmware Update for more details.
Build
  1. Select Critical Application Monitoring Demo from the Use-Case menu.
  3. Select Build.
Run the FVP
To start the FVP and connect to the Primary Compute terminal (running Linux):
kas shell -c "../layers/meta-arm/scripts/runfvp -t tmux --verbose"
Follow the steps below to achieve the same:
Refer to the following image of the tmux panes rearrangement. Panes can be navigated using Ctrl-b followed by the arrow keys.
Arm Auto Solutions Secure Firmware Update Virtualization FVP Windows
systemctl is-system-running --wait
Wait for it to return. The expected terminal output is running.
Run the Demo
    reboot
    FF-A driver 1.0
    FF-A framework 1.0
    [INF]:[FWU]: FMP image update: status = 0, version=0, last_attempt_version=0.
    [INF]:[FWU]: uefi_capsule_retrieve_images: capsule size = 18219116, image count = 1
    [INF]:[FWU]: uefi_capsule_retrieve_images: image 0 at 0x6500006c, size=18219024
    [INF]:[FWU]: flash_rss_capsule: enter: image = 0x6500006c, size = 16121872, version = 3
    Note
    Note
      shutdown now
      reboot: Power down
  4. Select Build.
Note
