Build host environment setup
System requirements
x86_64 or aarch64 host to build the stack and execute the FVP
Ubuntu Desktop or Server 22.04 Linux distribution
At least 500GiB of free disk for the download and builds
At least 32GiB of RAM memory
At least 12GiB of swap memory
Note
You can copy all command examples on this page from the HTML document format by clicking the copy button. In the PDF document format, be aware that special characters are added when lines get wrapped.
Install dependencies
Follow the Yocto Project documentation on how to install the essential packages required for the build host. The packages needed to build the Yocto Project documentation manuals are not required.
Install the kas tool and its optional dependency (to use the “menu” plugin):
sudo -H pip3 install -U pip && sudo -H pip3 install --upgrade kas==4.8.1 && sudo apt install python3-newt python3-kconfiglibFor more details on kas installation, see
Install tmux and telnet (required for the
runfvptool):sudo apt install tmux telnet
